1 - 9 of 9 Posts
Formerly known as wabbit1
Hi all,
anyone used one of these before? I want to remove the 2 lambda sensors from my stock downpipe and cat
http://www.ebay.co.u...=item19d160805c
Camera accessory Audio equipment Gadget Font Electronic instrument
If so how is it used
Ie, what tool fits into the square and star shaped holes
EDIT - found this Office supplies Tool Rim Writing implement Font at least this is one that I can use straight out the box
I've got the second one, not really necessary though as you can do it with a normal spanner. You only really need them for if there is very limited access and you need to use a socket handle and extension bar.
My spanners aren't offset so don't sit flat onto the sensor and slip off when i apply pressure
As above. Use a spanner.
Failing that we have a socket in the garage with a cut down it. Means you can put the wire through it
The tools on your top link just attach to a ratchet
Just use an angle grinder to put a cut down an offset ring spanner like your second picture. Try not to overheat the metal as it re-tempers and can ruin it.
1 - 9 of 9 Posts
