1 - 13 of 13 Posts
Hi Guys, I've just aquired a knocking noise when turning full right hand lock to get off my drive. At first glance I can't see anything out of place and she's only done 14000 miles. Any one got any ideas
FocusSTOC Nut!
hi mate. check the rubber boot at the end of your driveshaft in case it is split. if it is all the grease comes out of your cv joint and it will start to knock. a sign of this would be grease around the inside of your alloy. thats my best guess mate.
As the warranty runs out in May, it 'May' be time to buy a new one!! With only 14000 on the clock I'm a bit torn
With the weather we've had, I've not had the chance to have a look at the car today. Do you know if the knocking would only happen on a full lock, or would it happen as soon as you turn the steering?
FocusSTOC Nut!
think initially it wd happen on full lock, then it wd start to get worse and make a racket no matter how much lock your using. might not be this though could be an anti roll bar bushing or any number of suspension joints. best just take it to your dealer and let them sort it. maybe you could buy an extended warranty from your dealer to give you piece of mind, should be possible, especially with the low miles on your
. best of luck at the stealers
FocusSTOC Nut!
probably is true mate. think a new focus is on the horizon. if the fiesta is anything to go by there might not be an
version
certainly wont be one with a five pot under the bonnet. talk is it will be some sort of eco,boost turbo. the new
's are nice with the black wheels. gettin me thinkin now mate.
QUOTE(stingy @ 29 Dec 2009, 07:20 PM) <{POST_SNAPBACK}>probably is true mate. think a new focus is on the horizon. if the fiesta is anything to go by there might not be an
version
Black wheels? Didn't know they'd changed the colour of the wheels. Have to be carefull you don't kerb them or it'll stick out like a sore thumb!! I knew that the style of wheel was different but not the colour. If I do get one, it'll probably be montuned from the start with all the extras. Eco boost doesn't sound that quick..... back to the days of the
170 perhaps!!
FocusSTOC Nut&#33;
all come with black wheels as standard now silver is a cost option. the new engines are gonna be smaller and turbo charged 1.6 to 2.0 apparently they will be pretty powerfull and loads more economical. check out the autocar website, think there is some info and pics on it. mountuned sounds great, at least you get what it says on the tin (260)bhp & warranty. it cant be beat imho.
Discussion Starter · #12 ·
QUOTE(stingy @ 29 Dec 2009, 08:01 PM) <{POST_SNAPBACK}>all come with black wheels as standard now silver is a cost option. the new engines are gonna be smaller and turbo charged 1.6 to 2.0 apparently they will be pretty powerfull and loads more economical. check out the autocar website, think there is some info and pics on it. mountuned sounds great, at least you get what it says on the tin (260)bhp & warranty. it cant be beat imho.
Will they set the bhp to 267 I wonder. This suggests it could be quicker than the current
, but you won't get the addictive engine noise!!
FocusSTOC Nut&#33;
you never know mate. they will bring out all the shopping models first. then prob gauge the demand for an st version. they say there will be no rs, but they said that the last time to! either way it will prob be 2 or 3 years before we see a hot version. new cars are always heavier 2 so 267bhp might just be the same performance as a the st has now. anyway, best of luck with the knocking noise mate, stingy.
1 - 13 of 13 Posts
