Keyless Start
238 Views 8 Replies 8 Participants Last post by  Davieravie
Stupid question I was mucking about with the lads at work this morning and have found that I can drive my car around the yard at work with out the keys being in the car , so the question does anyone know if there's a distance that the car can go without the key in proximity of the car
1 - 9 of 9 Posts
I have the key free system on my pre-facelift. I don't know if there's a specific distance but I'll bet the car will keep going until the ignition is turned off
. When my fob is a certain distance away from the car I just get a message on the display, nothing more and the car keeps running!
Once started the car will keep running until the engine is switched off regardless of any distance between the car and the key fob, Not the best design in the world
QUOTE(Lee RS @ 2 Dec 2009, 01:56 PM) <{POST_SNAPBACK}>Once started the car will keep running until the engine is switched off regardless of any distance between the car and the key fob, Not the best design in the world
What he said!!!
The salesman in the showroom explained that he drove to work once with his wife, she borrowed the car to go down to London. Neither realised he still had the key until she tried to lock the car in london (over 150 miles away), OUCH!!!
That is very dodgy. Can see all sorts of problems there. Quite scary in fact
If you had to drive the car with keys it would defeat the 'keyless' part
QUOTE(Glenster @ 3 Dec 2009, 09:09 AM) <{POST_SNAPBACK}>If you had to drive the car with keys it would defeat the 'keyless' part
true but I think the logic behind it is to keep the keys in your pocket/handbag... Not dropping your missus off somewhere, driving off and only realising she has them after you have turned the car off and go to lock it
In fairness guys if the key is not in the car the Warning light and message come up to tell you.
QUOTE(ady282 @ 12 Dec 2009, 11:50 AM) <{POST_SNAPBACK}>In fairness guys if the key is not in the car the Warning light and message come up to tell you.
Then I bet £100 the salesmans wife was a blonde then!
1 - 9 of 9 Posts
