Hello to all you sexy ST owners.
A quick question! I've had a little look around the forums and can't seem to find the answer. I'm picking up my new ST-3 on Sat and i'm looking forward to using the bluetooth/USB i've got in it but i'm not sure what cable I need to listen to the music on my Iphone through it, is it a 3.5mm to 3.5mm cable??
Muchas gracias to anyone who can help with this newbie question.
Welcome
I dont have the fancy bluetooth & USB in mine so I'm not sure but think you might be able to connect an ipod via usb.
Anyway if not a standard 3.5mm male to male cable as you've said does the job well, I got mine from maplings for about a fiver.
Enjoy and I imagine the wait will almost kill you this week
Get your membership paid and read the modification forums...
Well that's the first time I've been called sexy
A: the normal iPhone cable that connects to you PC merely charges your iPhone. So as mentioned it's a 3.5mm to 3.5 mm, alternativley if you have the USB port fitted, copy all your music onto a memory stick and leave it in there then control you albums from the head unit SIMPLES, also you are not draining your battery on your phone and it's safer when driving to select your choice fom the head unit
Note: when copying music onto the stick make sure your music files are converted to MP3's
