I recently had an issue with my car failing to start which turned out to be my instrument cluster. I sent it to ECU Testing but unfortunately they were unable to repair as the unit was not powering up.
I understand that I can replace the clock cluster perhaps with a used part (if I can find one) and get someone to do a "suck and blow" / reprogramming.
My Focus ST is a MK2 06 plate.
Many thanks in advance.
- If my old unit is not powering up, is this possible if I get a replacement unit? (i'm guessing they get the data from the clock cluster, please correct me if I am wrong)
- Does the clock cluster have to be the exact part no as my clock cluster i.e. 6M5T-10849-PG ?
- Any recommendations where I can get hold of a clock cluster and any garages / services that can do this within the Braintree / Chelmsford area?
