I Need Your Opinions On What To Do With My Brakes
318 Views 9 Replies 8 Participants Last post by  troy45
would you upgrade your standard set up, or keep them the same?
brake decisions
yes keep it standard...its good enough1066.67%
nope..uprated pads/discs/hoses is the way to go533.33%
1 - 10 of 10 Posts
right, so i cant afford to upgrade to AP or anything like that, but i am considering changing pads, discs and hoses
a few very well respected members here who drive to the limmit dont think its necesary, but im interested in what others think
im very interested in what the guys that have upgraded think, as well as those that dont think its worth it
please state why you voted the way you did
I have a stage3 ST, so consider this before you vote
If you want to upgrade without going down the AP route - Ferodo DS2500 Pads on standard discs is my recommendation.
Don't bother with upgrading the hoses unless you're planning on using it on the track. I do run HEL hoses front and rear but in all honesty I cannot feel any improvement in pedal feel, and a good friend told me that was what was to be expected but didn't want to be giving me bad news
So I found out the hard way after buying them and spending a good few hours swapping hoses and bleeding new fluid through each corner of the brake system
The Ferodos are way better than the Mintex pads I ditched with loads of life left cos they squealed loads, left hot-spots on the discs and were wearing the discs with a slightly narrower sweep than the standard pads meaning a stepped lip was being left at the edge of the discs and would require skimming before fitting other pads.
In my un-expert opinion the standard setup is more than good enough for the road.
I do not believe that changing the standard hosses, discs, pads for some aftermarket replacements will make all that much difference.
I run standard front and rear discs, Mintex 1144 front pads, OEM Ford rear pads, Goodridge hoses all round and non silicone dot 5.1 brake fluid.
I feel there is a very slight improvement in pedal feel with the hoses, but not a lot.
Mintex recommend using OEM rear pads, I find the uprated pads very good, havent noticed a lot of squealing off them, However uprated pads do wear discs more than standard pads, Over the years i have fitted a lot of uprated discs (drilled/grooved) and they do create a lot of noise.
The set up i run cant be bad - My wife even said after i done it all that the brakes were better...
Id go with standard pads on the rear and the Ferodo's on the front. we'll thats what im gonna do anyway as im due new pads.
Unless you drive like a complete
on the road, in which case you are going to get
then in my opinion the standard brakes are more than good enough. They have good feel, work well, are cheap, last a long time and are more than capable of triggering the ABS at any road legal speed... If you do more than 2 or 3 trackdays a year though, then thats different...
All i shall say is that afew of us were running out of brakes trying to keep up with a certain member on here who drives a 1 series BMW. If you are looking to track the car in the future i would follow Troys advice
Why not try simulating a track style.
Find a straight "private" road build your speed up and brake from the highest speed possible - scrub maybe 60-70 mph off, accelerate again then repeat. Do this untill your brakes no longer work due to excessive fade, continue till the discs are warped and start to judder. After replacing the worn discs and pads, hopefully you will realise that if you need better brakes on the road you deserve to lose your licence.
Just a bit of friendly banter there
But you're not criticising people who have put brake upgrades on their cars obviously?
1 - 10 of 10 Posts
