How to remove key blade from top half of fob?
9.5K views 8 replies 5 participants last post by  dar83
There is a pin, if you look at the bottom of the blade you will need to have the key part open to see it, if you use a small screw driver and tap that out (dont lose the small pin) then slip the new blade in and tap the pin back in
Yes just as i thought, i used a panel pin/round nail and cut the point off to use as a punch, it helps if you have a vice or similar to hold the key blade.
Tap out the pin, replace the blade and tap the pin back in. Job done.
Theres some pics here that may help.
http://saab92x.com/viewtopic.php?id=8738
