· Registered
Installed my Breedt quick shift arm yesterday. Thought I would do a writh up.
I bought mine via Ebay from Anembo Engineering (http://stores.ebay.co.uk/anemboengineering/)
Fast shippment, good postage cost.
I recived my quick shifter in a labeled box, inside the arm was wrapped with bubble wrap. In some other reviews there is a punch pin taped to the arm (for driving out the stock pin), but not in mine.
There was no instructions with the arm and can't be downloaded from Breedt's homepage either.
But I emailed Breedt and got an instruction.
Box contained:
1 pc Quick shift arm
1 pc 10 mm ball stud (attached to arm)
1 pc M6x40 hex bolt
1 pc M6 lock nut
2 pcs M6 flat washer
7977-4188b7161052d3b24149a6049b943ee8_la
Tools needed:
10 mm socket (ratchet kit)
10 mm spanner
8 mm spanner (for tighten ball stud)
5 mm punch pin (50mm long or so)
Pliers/wisegrip to hold punch pin
Hammer
Flat screwdriver
Optional: 7 mm socket with extension bar (for hose clamps)
I dont have the stock air box but I've copied Breedt's instructions.
Stock airbox:
1. Disconnect the rubber air box deflector joiner and disconnect the MAP sensor.
2 Undo the rubber hose to crossover duct clip then unfasten the secondary air feed (lower) pipe. Disconnect vacuum line.
3. Separete the rubber hose from the crossover duct and remove airbox. To remove the airbox, pull the airbox hard upwards. The airbox is helt to chassi by 3 rubber grommets. If the grommets stick to the airbox, simply pull them off and reinstall on the car.
Revo airfilter kit.
1. Loosen hose clamp from intake pipe and remove airfilter with silicone bend.
2. Unscrew 2x 10 mm bolt holding the heatshield, remove from engine bay (one is located next to the groundning bolt and the other one is located under the bonnet latch). This will allow access to the shifter arm.
7977-cda97b02bb9d58f08321e21990aaabd8_la
7977-8510fc3e1d011b7d143b415430eadd5b_la
3. Pry of the shifter linkage cable with the flat screwdriver (or a separator tool).
4. Use the punch pin and hammer to tap out the roll pin (carefully). It may need some persuasion. I used some penetrating oil to help break the pin loose.
You wont be able to drive the roll pin all the way trough so it falls out.
Lift up the shifter arm and remove it.
7977-b828c10f04aceef899a63a3a43d6676f_la
Stock arm vs Breedt quick shift arm.
Weight difference
Stock: 1,16 kg
Breedt: 0,46 kg
7977-f5f7d3ff58ad7321cf94fc684ac4728d_la
5. Use the supplied bolt with one washer on one side of the arm (one at the hex head and one with the nut). Tigthen up the lock nut with the 10 mm socket and spanner.
6. Pick a position on the shifter arm (1 to 4)
P1 = 24% reduction, moves shifter forward 25 mm
P2 = 39% reduction, moves shifter forwards 25 mm
P3 = 40% reduction, stock shifter location
P4 = 25% reduction, stock shifter location
I went with P2 because it felt best for me when I tried it out.
When you have chosen, tighten the ball stud with the 8 mm spanner and reattach the shifter cable. It just clicks on, no force is needed.
Before reinstalling the airbox, ensure that all the gears can be engaged.
7977-a26f4edcba877b42e745440d5f4bc5f9_la
7977-1d7e9f9d1f836ec858be881db7594d62_la
7. Reinstall airbox/filter kit in reverse order of removal (in true Haynes spirit).
8. Take it out for a test drive and enjoy!
Impression:
For me, it was a bit awkward with the P2 position, because the throw is so much shorter. At first you don't think the gears are engaged so you try to press the shifter more in to its position.
I got used to mine pretty quick.
It feels much crispier and notchier, moreore precise. It clicks in to gear and you can feel it.
And it really is quicker to shift with. It's not like rowing a boat anymore!
7977-8f092c5c4a73431fe4b551169bd8f469_la
If you have any questions, please ask and I will help answer them. I hope this helps!
· Registered
Great guide. I found the install was pretty easy apart from knocking the pin out, that was a nightmare as there's not much room in the engine bay to swing a hammer. Lots of WD40 seemed to help.
· Registered
Thanks i'll go for it next month. No problems to engage the reverse gear ?
Mine can stick in reverse sometimes when I'm going from reverse to 1st
Yeah, the pin was a bit of work. Especially when you think that it will g all the way through. I pounded that pin, until I realized that it was free from the shaft :p
