Hi
I'm hopefully fitting my CAIS this weekend, weather permitting, reading through the instructions I says to disconnect your battery, but will need my radio code when finished to enable the unit again.
Q: before disconnecting, is there a menu/shortcut on the unit that displays the code? The unit is the premium satnat
Cheers people
You can't use the software to decode the newer units - or the DVD nav ones, the chassias number needs to be e-mailed to ford technical in Germany.
It will be a trip to the dealers i'm affraid.
Edit. Try a call to the origional supplying dealer, they may keep a record on their systems,
