help!!! St225 2007 Rattle that goes away when rev or under load,
11K views 22 replies 9 participants last post by  toadboy
#1 ·
Well I wanted to join the site happy that I had become the owner of my first St, but it's not the case ..... First of all, hi every one , I'm Tim ... In from Stockport in Manchester , I'm new to St but far from a ford Virgin.... Owned numerous cosworths and Rs cars over the years, but this St seems to of bitten me..... Well I hope and pray not ... But here goes.... So start the car, stone cold, no noise, let it warm up for 5 mins and rest your foot on the throttle when driving gently (saving fuel, yes I'm a fuel Jew!!) at anyhwhere from 1300rpm to 2500 ish and there's a horrid rattle coming from the engine.... It doesn't sound like bottom end (please God NO!)
It sounds like a follower or something, but I'm now in panic mode as I bought the car without knowing this fault and drove the 300 miles home , oil pressure on the gauge stays away from the red, and it's seems to be boosting standard (up to half way) but it has a dream works intake is it?? Across the engine, and a decay pipe... I'm Hopi g some one can help me on this issue as in seriously wiping my bum every 30 mins atm until I know the fault has gone away.... Any one experienced similar issues?
thanks guys
Tim
#8 ·
Thanks for your reply... Yea well when I say rattling, it sounds like metallic almost like a follower is bone dry at certain revs, which I am praying isn't bottom end.... I'm based in Stockport, I only use 1 garage , over the years I've used every single garage that's worth a look around these parts (I sell cars for a living ) and the best around is MC autos , on Alldis street, in great moor, Stockport.. They are awesome mechanics, hoping to take it in today on the off chance .... So will update accordingly.....
#10 ·
What's yours doing exactly? Mine sounds like something inside the engine is loose or growling when it does it... Watched a link last night on a 2010 focus Rs with a rattling ecu cover that sounded similar, however I don't think that's the same noise as mine sounds in the engine :(
Other than the fault how cool is the St really! I've genuinely fallen in love with it other than this fault..... Want to keep this a short while and buy a Rs replica like the rs500 rep on eBay,! Has anyone seen that car? It looks like a really good example for the £8500 price tag!
#18 ·
If you think the noise if from the bottom end then it's more likely to be the clutch/flywheel then the value follower.
Valve followers tend to be noisiest from cold, but you can get some treatment made by Forte for them. I'm not saying it's a cure, but if adding it quietens down the noise you've probably found the issue, if not time to look elsewhere.
#19 ·
My heart sank when I first heard the noise, but thankfully it was just the DMF. Was a blessing in disguise really :)
#21 ·
Now, sounds like a broken piston I think..... Doesn't do it from stone cold, does it more the warmer it gets, until it's at temp then stays as loud, have no idea how to put a video on here or I would.... Sounds to me like my old bora Tdi with chocolate can when I wore through the top of two of the lifters.... But I just can't find anything on the net that says the cams or lifters ever fail this bad..... It's a nasty noise guys..... Personally guys I Think it's over for this St 😞
