1 - 16 of 16 Posts
Well the tale of my ST is long these days, seem to be problem after problem just now. Newest one is the heated screen. Only the passenger side is clearing and the drivers needs done by hand, not too good on a
cold morning.
Has anyone experienced this before?
Kenny
QUOTE(kenny @ 28 Nov 2009, 12:46 AM) <{POST_SNAPBACK}>Well the tale of my ST is long these days, seem to be problem after problem just now. Newest one is the heated screen. Only the passenger side is clearing and the drivers needs done by hand, not too good on a
cold morning.
Kenny
Mine has stopped working on part of the screen, if you remove the wipers and scuttle panel you will see the foil connectors, one each side. Check they are conected.
One of mine has some corrosion so i guess its broke contact, but its part of the screen. So can't be repaired. I will be getting a massive stone chip very soon.
QUOTE(PHILJB @ 28 Nov 2009, 12:53 AM) <{POST_SNAPBACK}>Mine has stopped working on part of the screen, if you remove the wipers and scuttle panel you will see the foil connectors, one each side. Check they are conected.
LMAO Phil.. never thought of that m8y
I've had the same problem with two focuses. Got ford to replace screen under warranty guess what.... several months later.... same thing happened again...
QUOTE(northernmonkey @ 29 Nov 2009, 08:21 AM) <{POST_SNAPBACK}>I'd check the fuses first. I'm sure it's a different fuse for the drivers side to the passenger side!
Just a thought!
my mum had an H reg Escort with the same issue nack in the 90's (before i wrote it offf) and it was a fuse that was the issue so they used to have 2 fuses so may well still be the case
My passenger side isnt working and I have just had a look in the owners handbook and they are on different fuses. No 14 is the RHS and No 16 is the LHS both 40 amps. I am going to check mine today.
cold morning.
Kenny
Mine is &^%$ too. Did you guys have any luck with the fuses?
QUOTE(matty779blue @ 4 Jan 2010, 08:09 PM) <{POST_SNAPBACK}>Mine is &^%$ too. Did you guys have any luck with the fuses?
I had no luck with the fuses and my new windscreen has arrived at Fords. Just need to find the time to get it fitted.
Mine only works on one side too. Took the cover off under the windscreen and have found that one of my ribbons are broken!
There are two running up to the windscreen if you werent aware. I need a new windscreen to fix this, although car is still under warranty maybe worth a try
QUOTE(DeanST @ 4 Jan 2010, 10:00 PM) <{POST_SNAPBACK}>Mine only works on one side too. Took the cover off under the windscreen and have found that one of my ribbons are broken!
This should be a warranty job
One of the ribbons on mine is corroded so only part of the drivers side works.
Must get round to getting a BIG stone chip.
Mine is getting fixed under warranty.
QUOTEround to getting a BIG stone chip.
that would be good excuse!
Have managed without it but with the cold weather I am missing it! Spend a fiver running the car in the drive or get out and scrape the windscreen
Discussion Starter · #15 ·
The tabs under the scuttle panel were the problem. New screen ordered under warrenty.
i cant get mine done under warranty because its an autoglass screen, and autoglass fitted it incorrectly. the drivers tab is supposed to go under the wiper mech, but they fitted it over the mech, so when i put wipers on it broke it off the screen
and its got no autoglass warranty as it was done for the previous owner, so this weekend it shall be getting a meeting with mr center punch lol
1 - 16 of 16 Posts
