ST2 2006 Pre-facelift. My passenger side headlight washer cover seems to be lifted slightly on one side as it doesn't sit flush with the bumper. I've tried giving it a whack down on the top but no luck, it goes down but rises again slightly after a while.
Anyone seen this before and if so how do I fix it? Is it the cover becoming loose, the washer still operates properly.
The cover will have popped loose from the clip, get someone to operate the washer jets, and grab hold of the washer arm while its out of the bumper, then you will see how the cover clips onto the white bracket thing... It is a rubbishy fit, probably just needs re-seating.
Also, make sure the white bracket is clipped onto the arm properly, it uses 2 pins and 2 little "knobs" it sort of clips to, you will see hwat I mean when you have hold of it....
