Little update.. you never know if a ford rep is reading..
Contact Ford customer services who confirmed the following:
As they dont know the cause of the problem the process will go like this
1. They can check out the gear box
2. They can check out the Clutch n bits
If no problem is found, I WILL BE BILLED FOR THE LABOUR (6HOURS)
if a problem is found to be a manufacturing issue - THEN WILL BE REPAIRED FOR FREE (IF THEY DONT F*CKING LIE TO ME, AND SAY ITS MY FAULT ANYWAY)
If a problem is found to be my fault - WHICH IS IMPOSSIBLE AS I'VE HAD THIS PROBLEM FROM VERY EARLY ON, THEN I WILL BE BILLED FOR PARTS AND LABOUR. THEN YOU MIGHT AS WELL JUST CRASH THE CAR AND BUY A NEW ONE cus this will get expensive.
But ofcouse it will be my problem, ofcourse I would have caused it..... its been there since DAY ONE. Is it worth the risk and getting them to find the problem??? no..what if they do lie?? then I'm f*cked. and i wanted to buy this from ford as well in october this year. instead they can stick the car up their
. I'm going to Subaru or something..
anyone got an opinion on this one?
p.s (regarding this issue - The other day I went to overtake a lorry in second, half way past the lorry i went to change to third, wouldnt go in, then wouldnt go in 4th etc.. times passing, on coming traffic... nearly died.. thanks ford. )
