QUOTE(glennboysst3 @ 30 Nov 2009, 09:44 PM)
<{POST_SNAPBACK}>sorry but i cant understand why people fit a 3 inch sytem then use stock gskts !
try torquesteer as they do a full 3 inch gskt set from HKS ,why fit a 3 inch sytem then restrict flow past the standard gasket ??
kinda defeats the object of fitting a bigger bore sytem ,if you go to the lenth of fitting above then fit the 3 inch gskts in my opinion .
EDIT should of read the first post as hes only fitting down pipe !!DOH
