What state of tune is you're engine in? I'm running a purple spring and 8.5psi preload but I'm running mod x rs with supporting mods.
What state of tune is you're engine in? I'm running a purple spring and 8.5psi preload but I'm running mod x rs with supporting mods.Hi all
iv just ordered the forge rescirclating valve which colour spring should I use the yellow or green one?
thanks
As far as I’m aware it’s been block moded and the rest is pretty much standard. As we just starting out. So not sure which spring I should useWhat state of tune is you're engine in? I'm running a purple spring and 8.5psi preload but I'm running mod x rs either supporting mods.
Green spring and 4.5 psi of preload for standard tune I believe .As far as I’m aware it’s been block moded and the rest is pretty much standard. As we just starting out. So not sure which spring I should use
I’m going to remap my car soon should I put the other spring inyellow spring for a remaped car pushing 300 or more..
Really not sure tbh what is the best map for my carwhat map are you going for?
That’s the thing so many to choose from but what is the best. We already have the ram air filter, AirTec intercooler and forged recert valve. Blocked moded , r/s vac pipe.plenty out there the choice is yours..
'Best' is personal choice, people can tell you what they have but whether you'd like it or not is a different matter.That’s the thing so many to choose from but what is the best. We already have the ram air filter, AirTec intercooler and forged recert valve. Blocked moded , r/s vac pipe.
