For anyone fitted mk3 rs calipers to mk2 st looking for some help please. Slowly getting there now. Got 5mm hubcentric spacer fit between hub and disc. But done a small trial today with how many turns i can get with spacer on. Only put the spacer behind the wheel rather than take calipers off as just trial perhaps that makes a difference i dont know. Without spacer i get 7.5 turns with et40 wheels so on the limit id say. With spacer 4.5 turns. Few people that done its been fine so confusing part there.
Options im thinking
1- using longer nose nut but i dont think thats going to give me much more
2- 15mm spacer with its own studs. So then i got enough thread to bolt both sandwich spacer and wheel spacer to hub and wheel to spacer. Cheaper easier but spacer aint for car especially if using abit of track days
3- use longer studs from burton but that means new wheel hub aswell so very expensive option.
Any advice please
Thank you
Options im thinking
Any advice please
Thank you
