as you say V8 SAM the r s plugs come pre gaped
got mine this morning with a thump through letter box
any one know the correct gap for these as they may need re gapping
due to method of delivery
The ford plugs come in a box with a cardboard collar that protects the end of the plug.
there is no harm in checking the correct gap, I'm sure somebody will post the correct gap
QUOTE(denboy @ 19 Nov 2009, 11:07 PM) <{POST_SNAPBACK}>think the normal gap is 0.7mm,when i fitted the new plugs i had them gapped at 0.5mm,purely because of the amount of boost i,m running.
Denboy - were you getting what sounded like a misfire at high boost, was this the spark being blown out, hence the reason for reducing the gaps??
Please excuse me for being a tad thick here guys but could someone tell me what difference these plugs make on the performance i may be tempted to get a set myself,
thanks
QUOTE(Tall Person @ 19 Nov 2009, 11:42 PM) <{POST_SNAPBACK}>Denboy - were you getting what sounded like a misfire at high boost, was this the spark being blown out, hence the reason for reducing the gaps??
you are correct,drove 30 miles home after my service and so far, seems to have cured it.
QUOTE(BadgerST2 @ 20 Nov 2009, 12:03 AM) <{POST_SNAPBACK}>Please excuse me for being a tad thick here guys but could someone tell me what difference these plugs make on the performance i may be tempted to get a set myself,
thanks
Unless you have a problem with misfires they will make no improvement to the performance! However they are a different heat range to the ST plugs so should prevent any problems with misfires/plug fouling occuring in the future!
QUOTE(BadgerST2 @ 20 Nov 2009, 11:14 PM) <{POST_SNAPBACK}>Thanks for that mate i have no problems at all so far got the stage 1 bluefin and so far am very happy with the results
In that case i would still get a set and fit them next time the car needs plugs! They are actually cheaper than the ST plugs!
1 - 13 of 13 Posts
