when fitting the rs ecu cover did you have to remove one of the coolent hoses? looks very good m8 i think i will have to fit the ecu cover
QUOTE(LiamX8 @ 7 Feb 2010, 03:01 PM) <{POST_SNAPBACK}>when fitting the rs ecu cover did you have to remove one of the coolent hoses? looks very good m8 i think i will have to fit the ecu cover
yes m8 but easy to do
once u remove headlight the hose is visible and jubilee clip easy enough i did it wen engine was cold n barely lost any coolant either re-route the hose under the loom then reconnect
hope this helps m8
QUOTE(paul-stfoc @ 7 Feb 2010, 03:19 PM) <{POST_SNAPBACK}>yes m8 but easy to do
hope this helps m8
hopfully fitting a dsci kit soon i have a code red ecu cover all ready fitted will this be ok or will it get in the way of the dsci pipe as it goes down behind the headlight
QUOTE(big kev @ 7 Feb 2010, 06:57 PM) <{POST_SNAPBACK}>hopfully fitting a dsci kit soon i have a code red ecu cover all ready fitted will this be ok or will it get in the way of the dsci pipe as it goes down behind the headlight
Have you got a picture mate? It's very tight where the induction pipe goes to be honest
