Exhaust Problem(the Miss)
237 Views 8 Replies 8 Participants Last post by  Jim G
i have fitted a MS Design rear diffuser and my standard exhaust tailpipes are looking a little
small. Does any one no where i can get large tail pipes to fit over them, my miss wont
let me unpgrade the exhaust, says they are to noise, can any one help(i do wear the trouses in
the house by the way)
1 - 9 of 9 Posts
If you've fitted a new rear diffuser, you need to uprate the cat-back.
If you don't, the wankel flange trumpets on the new diffusion layer outbreaker will cause tappet grind and destroy your big end.
Just keep going on in that vein for a few hours and I'm sure she'll cave in...
Not sure about new tips for the existing cat-back.
/\ Loving that,
you can but them from halfords, but they will look utter tosh. Get some pics of the diffuser up
QUOTE(razzleultra)If you don't, the wankel flange trumpets on the new diffusion layer outbreaker will cause tappet grind and destroy your big end.
need to
as well
Mike
Yeah but if you dont take car of your wankel flare trumpets then the secondary hysteresis circuit on the transfunctioner relay will cause resonance and give an improper date signal.
You'll need to match them up with the wibble valve too. And maybe fit new overhead tickle adjusters.
Simples
QUOTE(bully09 @ 27 Nov 2009, 05:50 PM) <{POST_SNAPBACK}>i have fitted a MS Design rear diffuser and my standard exhaust tailpipes are looking a little
Get yourself a new dreamscience full system and tell her you only bought the tail pipes.
1 - 9 of 9 Posts
