5th and 6th are locked out. I know the ABS sensors calculate speed im just wondering what the A stands for in the fault code. I was hoping it meant a specific hub! Have read someone its the o/s/r? Was just hoping someone could elaborate! Will drop Andy from A & K motorsport a message time see if he has any information.Is the performance affected in terms of boost being held back etc, do you get any strange ABS activation, difficulties getting into 5th / 6th gear?
The car does not actually have a central vehicle speed sensor on the gearbox, the vehicle speed is calculated from the ABS sensors. This code can can sometimes be caused by damage to a wheel bearing which supplies the signal to the ABS sensor. It may also be an ABS sensor itself failed, or wiring damage.
Cheers Alex.A garage with ford software should be able to find which sensor it is, I had same issue on my fiesta, threw up a generic speed sensor code but with ford software he could tell which hub was at fault.
Easily removed the torx bolt Rob but even after plenty of penetrating spray the sensor was stuck solid.The sensor has a torx screw holding it in Danny. It has a plastic body so should just pull out.
Just used a small socket, like a 4mm or something and knocked it through until it came out the other side then cut it out with some wire cutters.Lol, how did you get the rest out?
Conditions there in the UK are worse than here. Your cars age twice as bad as ours underneath.
Dumb thing to ask but are thease on all four corners thanks in advanceEasily removed the torx bolt Rob but even after plenty of penetrating spray the sensor was stuck solid.
View attachment 875241 View attachment 875243
As you can see, no way this was just pulling out! It has been in there for 14 years so cant really complain! Ha.
Thank ypuYes, one per wheel![]()
