1 - 11 of 11 Posts
hi people, picked up my st-3 yesterday, the man showed me the blufin handheld and told me its set to full power and that the engine managment light doesnt like whats going on and comes on on the dash,he said i justhave to turn it down from full if it does it,could it be anything to do with the fact the car is de-cated and they have 2 oxygen sensors dont they? has any one bought a spacer for the second oxygen sensor to remove it from flow of the exhaust. or should i just upgrade to dream science. also boost spikes 1.2 bar and holds 0.6.is this right. any advise would be great:)
QUOTE(denboy @ 13 Dec 2009, 12:29 PM) <{POST_SNAPBACK}>you can turn the light off with the bluefin,try and find out what map is currently on the handheld.
ok ill do that shortly and let you know, also how do i upgrade to level 3 bluefin when i get an intercooler etc and wpould you recomend a gen 2 k&n kit or one of these cais as they are realy expensive.
QUOTE(jamesmacc2008 @ 13 Dec 2009, 01:44 PM) <{POST_SNAPBACK}>ok ill do that shortly and let you know, also how do i upgrade to level 3 bluefin when i get an intercooler etc and wpould you recomend a gen 2 k&n kit or one of these cais as they are realy expensive.
if you have stage 2 on the bluefin,it will cost you £50 or so to get the stage 3 map from superchips,once you have got that,the stage 3+ is a free upgrade.
read my signature,i use the auto specialists cais,cheaper and imho just as good.
QUOTE(denboy @ 13 Dec 2009, 02:08 PM) <{POST_SNAPBACK}>if you have stage 2 on the bluefin,it will cost you £50 or so to get the stage 3 map from superchips,once you have got that,the stage 3+ is a free upgrade.
i did the model number and it said 41dc,is that stage one or two? any links for the cais as i may get one
Don't think you can actually read off the Bluefin handset which map is actually installed. And the dealer has led you slightly astray saying you can just 'turn it down from full power'
Depending which level map you've got you can download the Superchips Bluefin Desktop software then ask them to email you the maps for your handset (up to the level the handset is at) and then you can connect to the PC to change which map is on the handset. So if your handset has been upgraded to Stage 3 you'll have Stage 1, Stge 2 and Stage 3 maps to play with, if it's not had the Stage 3 upgrade then you'll have versions of Stage 1 and Stage 2 to play with.
Stage 2 is a free upgrade from Stage 1, and you can ask Superchips to include the decat file for Stage 2 to stop the light coming on.
Best to ring Superchips or pm Jamie on here (forum ID Superchips) I think they'll need your car's VIN number and the serial number off your handset to determine which maps you've got access to.
There's quite a few CAIS to choose from for your ST - determines how much you want to spend and if you want more induction noise or go the quiet route. The K&N is a good kit and I ran it on mine for a few years before I did some mods to it.
QUOTE(troy45 @ 13 Dec 2009, 07:05 PM) <{POST_SNAPBACK}>Don't think you can actually read off the Bluefin handset which map is actually installed. And the dealer has led you slightly astray saying you can just 'turn it down from full power'
ok thanks ill do a search for him on here
1 - 11 of 11 Posts
