Should your car turn out to have the same wiring issue as mine and
@DavLinz2011 , it's not a difficult repair and easily achieved with basic toolkit of screwdriver, spanners and Socket Set.
It's possible to get at the DPF Sensor wiring without removing anything, but it's pretty tight to see and access with the battery tray and air feed pipe in the way, that's why I removed the AirBox, Feed Pipe, Battery and Battery Tray during my repair, just made it easier to get at the wiring loom.
Basic steps are as follows:
1. AirBox & Feed Pipe Removal - Disconnect the sensor near the AirBox, lift up the rubber flap where the AirBox Lid meets the Slam Panel, loosen the clamp at the top end of the feed pipe and pull that end free. The entire AirBox can then be removed as one whole unit, it just pulls upwards to release from it's rubber mountings underneath the AirBox.
2. Remove the plastic battery covers, Disconnect the battery terminals (Easier the remove connection to the rear negative terminal by removing the end that bolts onto the top of the suspension turret). Remove the metal battery clamp, lift the front of the battery tray upwards, it should release and fold down to allow the battery to be slid forwards and out of the battery tray.
3. Remove the DPF Sensor off the side of the battery tray.
4. Remove the battery tray, If I recall correctly there's 2 or 3 bolts in the bottom of the battery tray, once these are removed the whole battery tray can be lifted out, which then gives you much more room to access the wiring loom to check for breaks.
There's likely some videos on YouTube that also demonstrate how the remove these items, often the videos are are easier to follow than written instructions.
I'm certainly no car mechanic, I'm an IT Engineer by trade, but I found it to be a relatively easy repair.
If you're anywhere near the Northamptonshire area, I'll gladly help you check your car for the same potential wiring issue.
For me, this was a much easier option than removing the DPF and associated pipe work to check for soot build up and blockages, that would have been very much the last resort, or even a garage visit for my abilities.
Keep us posted on your progress, fingers crossed for a speedy and inexpensive resolution.
