1 - 20 of 63 Posts
Fitted some Eibach front springs this afternoon - so i thought id do a quick 'how to'
Automotive tire Hood Automotive design Tire Motor vehicle
Remove 15mm bottom shock bolt and push out rubber brake hose from clip
Motor vehicle Automotive tire Automotive design Automotive exterior Automotive wheel system
Automotive tire Gas Automotive wheel system Cylinder Machine
Undo top anti-roll bar nut - 15mm
Automotive tire Motor vehicle Automotive exterior Bicycle part Bumper
un-plug ABS sensor
Automotive tire Tire Tread Motor vehicle Synthetic rubber
Leg Automotive tire Bumper Motor vehicle Automotive exterior
using a long bar put pressure under the shock and then give it some!!! - as per picture
Motor vehicle Automotive tire Gas Auto part Rim
after some 'light' force, the shock will pop out
Hood Automotive tire Automotive lighting Trunk Motor vehicle
open bonnet and remove small metal clips that hold the plastic cover on and un-do both small screws(1 each end)
Hood Motor vehicle Automotive design Automotive tire Automotive lighting
you can then access the 3 bolts which hold the shock on - the one at the back is easy to get to - just lift the plastic up to gain access
Automotive tire Motor vehicle Automotive design Gas Automotive lighting
shock removed
Shoe White Automotive tire Road surface Aluminum can
chalk a line down the shock - so when re-fitted you know the orginal postion
Now remove the top nut - 18mm, for anyone who's fitted shocks before its very strange but you dont need spring compressors to clamp the spring
Automotive tire Rim Gas Electrical wiring Hose
use a screw driver and prise up the rubber boot - then remove the old spring
Tire Wheel Automotive tire Motor vehicle Tread
fit the new spring, line up the chalk marks and secure the 15mm top nut
re-fit the shock to the car(top first) secure the three 13mm bolts
Automotive tire Tire Automotive lighting Wheel Motor vehicle
place a jack under the bottom ball joint and re-fit shock into the suspension leg - proberly the hardest part is getting the shock back into the leg - keep taping with a hammer and jacking slowly keeping pressure on - the shock will slowly go back in
Automotive tire Motor vehicle Rim Bumper Automotive fuel system
not a great picture, but two things to keep an eye on - make sure small metal locacating clip on back of the shock stays central and once shock is in, make sure its fully upto its metal stop
once your happy its fully in re-fit bottom bolt, re-fit anti roll bar and push brake hose back in
now do the other side!!
Tool Font Office supplies Household hardware Hand tool
picture of the tools i used
edit
make sure you remove the headlamp adjuster on the osf lower arm before taking the shock out
That is a great step by step. Very easy to do. Strange why the springs dont have any compression. Did you do the rear springs? Would have liked to see how the rears were done. Looks as if it is just one bolt to take off.
Discussion Starter · #12 ·
Yes i did change the rears aswell, did those the day before but the camera messed up
- basically the rears involve un-doing one bolt and using a spring compressor to help remove the old spring
Just a answer to someone who asked about just changing the rears - not a good idea, it dosen't seem to reck the handling, but the rear sits lower then the front!!
QUOTEGlad you got the Eibachs, you know it makes sense
What do you think of how its improved the drive?
totally transforms the handling when pushing hard - but normal driving keeps the car feeling standard
p.s anybody thinking about fitting the springs should speak to Malcolm - his review sold them to me
Only just read this and think it's a top job done by Jamie. And the Word doc linked here too
I still can't decide on springs or not - know it improves the handling I'm just wary of scraping my mudflaps even more and how the car looks lowered. Need to see some ST's in the flesh with the eibachs on.
I did the rears a bit different from the link above, after hearing of people having problems wh the bush splitting where the bolt passes through the suspension arm I decided leave it alone. Instead I undone the bolt holding the rear strut on to the hub, then got some spring compressors on the spring. After pushing the whole rear hub down the spring came out pretty easily.
Managed to dig out some torque settings to go with the How-to's above......
Front End
Strut brace top bolts - 32Nm
Stab bar to strut - 48Nm
Strut to steering knuckle 90Nm
Strut Top Nut - 50Nm
Rear End
Stab bar joint to lower arm - 48Nm
Damper to wheel hub/knuckle - 115Nm, nip up then fully tighten when weight of car is dropped back onto wheels!
Rear lower arm to knuckle 115Nm
Just ordered springs for my ST2 so the instructions will really help, I have a mate who use to fit shox so has kindly offered to help me as he has all the tools as well.
I've seen a couple of ST's that have got Eibachs fitted and they just look so much better than standard. Hopefully fitting them next weekend. Checked with my Local Ford Dealer and he believes that if you fit Eibachs then it wont effect the warranty as they are Ford approved.
Fitted the springs this morning, took around 21/2 - 3 hours in total, car looks great has made a real difference to the handling but ride quality is pretty much as it was, so £130 well spent.
Thanks again for the how to.
1 - 20 of 63 Posts
