2016 ST3 Mk3 facelift. 24,000 miles ,I started developing what I believed may have been wheel bearing or tyre noise, it occurs from 5mph it doesn't change in pitch, tone, audible it's a low humming droning noise sounds like it's front end but with all windows down it's quite audible from the outside, it doesn't change with different road surfaces but it echoes if I drive over lines across the motorway lanes were sections of surface has been laid.
2 months is been going on and I've changed...
All shock absorbers including mounts
All wheel bearings
Both driveshafts
Tracked ends and bottom ball joints
3 times checked alignment (Hunter)
4 new michelin pilot sports
New discs and pads
Engine and gearbox mount
It's audible with clutch in or out and in neutral or in gear with no change
Is this looking like Transmission bearing somewhere I can't locate the problem with stethoscope with front wheels spinning under load on garage ramps
All wheel bearings
Both driveshafts
New discs and pads
