Got the dreamscience induction kit and found it started to knock against the strut brace, i have solved the problem for now with some pipe insulation foam around the rollbar.
Just wondering what other people have done to solve this problem if you have had it?
Adam
I really need to sort mine out as well. On my second piece of pipe insulation now as the last one started to wear thin.
When it warms up I'll rope my brother in to holding it forward whilst I tighten everything up
i had this and wot i did was put a block of wood between induction pipe n strut brace to get the desired gap after i had undone jubillee clip at back. then the bracket to side of block
by doin that i was able to twist induction pipe ever so slightly which pulled it away from the strut, then retighten block bracket tight then retighten jubilee clip
i tried moving it with hands after n cudnt get it to knock on strut
hope this helps??
QUOTE(paul-stfoc @ 7 Feb 2010, 03:36 PM) <{POST_SNAPBACK}>i had this and wot i did was put a block on wood between induction pipe n strut brace to get the desired gap after i had undone jubillee clip at back. then the bracket to side of block
hope this helps??
Great idea matey I will have to copy you
