Evening all,
It's been a while since I have posted but I am hoping a few of the sites oracles can explain the tread pattern on the Goodyear Eagle F1 Asymmetrics. I need 4 new tyres and after running two of these on the front I am incredibly impressed and was about to buy a set of four.
However, I am confused about how the tyres which will be fit to the left side of the car can be doing the same job as the ones on the right as the asymmetric pattern will be running backwards (the tyres are not directional and don't have a different tyre for left and right).
I guess I should just be happy that they work - but I prefer to understand what's going on
Here are a couple of images of the tyres as they will be fit and you can see the patters are reversed. This would be front left & front right as looking from the front of the car.
You would expect that if the tyre on the right (above) is designed to expel water, then running backwards as the one on the left would be, it wouldn't be very efficient at expelling water???
You would expect the tyres to look like this from the front:
Here is a thread where someone else is discussing the exact same thing (where I pinched the images).
http://www.bimmerfest.com/forums/showthread.php?t=296677
Anyway, if anyone can shed some light on it, it would be hugely appreciated
Cheers,
Sean.
.gif)
.gif)
Cheers,
Sean.
