1 - 9 of 9 Posts
Hello All,
If I disconnect the battery do I have to reset anything when I reconnect it.
The reason I ask is that I used to have to reset my windows on my old astra so I hope it not as a stupid question as it sounds...
Only think that resets is radio, trip meter (and bits) and air con.
You'll need the radio code. Everything else is ok.
From the book:
Resetting the memory of the electric windows
WARNING
The anti-trap function is deactivated until you have reset the memory.
After the battery has been disconnected from the vehicle you must reset the memory separately for each window:
Note: On vehicles with a convertible top,
the roof and doors must be fully closed
before carrying out the following
procedure.
1. Lift and hold the switch until the window is fully closed.
2. Release the switch.
3. Lift the switch again for one more second.
4. Push and hold the switch until the window is fully open.
5. Release the switch.
6. Lift and hold the switch until the window is fully closed.
7. Open the window and try to close it automatically.
8. Reset and repeat procedure if the window does not close automatically.
That's basically the same as the astra.
Many thanks and I don't feel so stupid now!
Can you do this anytime. Or only after the battery.
My drivers window goes down auto. But not up.
And my passenger one is completely manual.
It'll only go up automatically if you have the global close option pack. To check for this go outside and hold your unlock button, if all the windows go down, you've got it. Saying that, I'm not sure if that option will work before you reset everything
I suppose the other way to check for it is if your up button has the same two clicks that the down has. Mine doesn't click upwards for example.
1 - 9 of 9 Posts
