hello all i'm running a full mongoose exhaust with a decat that was fitted to the st when i got it now its mot time and i have no cat to replace it with but have found one on ebay are these a straight swap (as in take the decat off put the cat in mot then swap over again) or do i need other bits for the swap
You will need to replace the de cat with a cat and then run your car for a couple of hundred miles before taking it in for it's MOT to give the system time to realise that it has a Cat fiited and pass the emmisions test
PS It's a straight swap by the way
You would be much better off getting a sports cat mate, your insurance is probably void when having a decat fitted. If you have an accident, your in the brown smelly stuff....
