Creaking clutch pedal!
945 views 4 replies 4 participants last post by  Wayneo1987
#1 ·
Has anyone noticed their clutch pedal creak when its pressed down?
Mine does it all the time. Sprayed it with wd40 and still the same.
Driving me insane!
#4 ·
Driving me insane!
It could be the return spring, you could try removing it and trying the clutch without it to see if it's still making a noise.
It's pretty easy but there's some decent info below about the setup so you can see how it can be removed/replaced. If it is the culprit you could always treat yourself to the Steeda upgrade...
https://www.focusstoc.com/forums/topic/530401-mk3-fitted-the-steeda-clutch-spring-what-a-difference/?hl=%2Bsteeda+%2Bspring
#5 ·
Thanks for the info!
Funny enough I saw the videos on the steeda springs. So this afternoon I took the spring out, managed to dismantle it and grease the spring thoroughly. I tried the pedal without the spring and it was silent. So ordered a steeda spring for £19.
Put the original spring back and it was gone! Drove it home from work for 20 minutes and just as I pulled up it creaked again! Damn thing!
Got the steeda spring coming so hopefully thatll make the difference now.
