just had a a accident in the snow hit a step
. just wondering are inner and outer track rods the same as a normal focus or does th st have a wider track ....?????
just checked and front wishbones are different. (prefacelift)
front,
track rod ends... the same
tie rods... the same
steering rack... different
hub....same
knuckle...same
rear,
hub...same
lower trailing arm...different
upper trailing arm...same
suspension arm.. looks to be different
rear knuckle/swing arm... looks to be the same
thanks
hoping its just inner and outer tie rod on driverside .. hit both drivers side wheels off a step back seems to be fine will have to check on a ramp tomorrow ....
there has been two st's in my bros workshop this holidays with same damage both had to be done through insurance make sure you get it well checked over as most of the damage will be hidden mate.
