1 - 3 of 3 Posts
Hi guys, first post so please go easy and excuse me if the answer to my problem is elsewhere in the forum!
A couple of weeks ago my ST developed a whining noise from the drivers side of the engine compartment and the engine warning light was on. I was a short journey away from home at the time so nursed it home to have a proper look. By the time i got home noise had dissapeared but after looking around the area the noise had been coming from i found a hose had split from the top of the oil filter assembly to the rocker cover. I got a new hose from ford and fitted it myself as its only connected by a jubilee clip however as soon as the hose was fitted the horrible whining noise started again. I had a read on this site and understand that the problem is most likely a burst oil filter diaphragm as the noise dissapears when you remove the oil filler cap. I put the car into ford on friday and suggested to them about the oil filter diaphragm and asked them to check the engine warning light. Car was in for a day and they claimed to have a diagnosed the problem as a "crank valve assembly" fault. They couldn't give me a price for the fix as there having problems getting the part in apparently.
Can anybody shed some light on this crank valve assembly fault? I assume there diagnosis has come from the fault code on the ECU.
I'll probably put the car back into ford once they give me a price but i'm wary that they may be barking up the wrong tree and that I'll still have a hefty bill to have the oil filter repaired afterwards
any help would be greatly apreciated
Vendor
I suspect that the dealers explanation of 'crank valve assembly fault' has got lost 'in the translation' somewhere.
I am certain that your diagnosis is probably correct and it is the dreaded diaphragm valve. We work on these all the time and not yet come across a 'crank valve assembly fault'
However it could be possible to describe the oil filter diaphragm valve as a 'crankcase breather valve assembly' in which case you are both singing off the same hymn sheet
I think this post should be in the technical problem area - maybe one of the nice moderators can move it for you.
thanks Wolfman, it wasn't the fellow who checked the car that i spoke to so you're probably correct!! It's even printed on the invoice as "Crank valve assembly" haha
anyway thanks for your help, hopefully have it running sweet as a nut again soon
1 - 3 of 3 Posts
