1 - 14 of 14 Posts
· Registered
Hello all,
Got a coolant issue, it's currently leaking out. Managed to find the root cause where it's leaking, but not sure what the part is called.
I have attached some images below, if someone can help me out with the name of the part - I'd highly appriciate it!
Also, what is the cause of this to be leaking? I've noticed the coolant tends to be emptied quickly when putting my foot down on the accelerator.. but when driving steady, coolant is slowly emptied.
T
Automotive tire Motor vehicle Automotive design Automotive exterior Vehicle
Tire Automotive tire Motor vehicle Wheel Black
Thanks,
Eduard
· Registered
Discussion Starter · #12 ·
Just an update.
Managed to replace the whole thermostat housing, was a big pain to get the bolt at the back.
The issue seemed to be just the gasket seal has eroded, hence the reason it was leaking from the side of the thermostat housing.
Ended up replacing the whole part just incase.
This was the seal I'm referring to:
Font Rectangle Auto part Circle Event
1 - 14 of 14 Posts
