1 - 16 of 16 Posts
I have bought some genuine parts from carpartsexpress I just want to confirm they are genuine parts and correct for car.. Where can i find this out?
Front Discs part no.
Rear Discs part no.
Service Kit part no.
Focus ST-2 56 plate
[background=rgb(236, 236, 236)]front discs : 1384290[/background]
[background=rgb(236, 236, 236)]rear discs : 1500156[/background]
[background=rgb(236, 236, 236)]still looking for the service kit[/background]
got service kit off ebay
Oil Filter 1421704​
[font=Arial, Helvetica, sans-serif]Pollen Filter 1354953[/font]
[font=Arial, Helvetica, sans-serif]sump washer 1386502[/font]
[font=Arial, Helvetica, sans-serif]Oil 5litre 1502266 x1[/font]
[font=Arial, Helvetica, sans-serif]oil 1 litre 1502263[/font]
They all correct apart from front discs ?! I have 1724956 on CPE on front disc section none have that code you lot have said ..?
Ford Focus Front Brake Discs
Products | Ford | Focus | Focus 2004-2007 Mk2 | BRAKES | Brake Discs | Ford Focus Front Brake Discs
Genuine Ford Focus Front Brake Discs PRICE PER PAIR
Price
Focus 06/03-01/08
1501069 £74.73
For All Zetec-S/Duratec 16V Engines (278mm Discs)
Focus 06/07-01/08
1520297 £84.91
For 2.0 Duratec, 300mm Discs
Focus 10/05-01/08
1724956 ST £85.00 *************
For ST Models 10/05-01/08 *********
Focus 06/06-01/08 *******************
F1501069 £74.73
For 1.6 TDCI 278mm Discs 06/06-01/08
Focus 06/06-01/08
f1520297 £84.91
For Engines 1.8/2.0 TDCI 300mm Discs
Chances are they are correct and ford changed the finis as they have done in the past, best bet is to hit a fords parts department when they reopen and ask for the code.
That is the correct finis, Ford do change them every now and again, often when it's an uprated or redesigned part etc. Don't worry though they will fit.
Graham at Car parts express knows his stuff I'm sure Ford have changed part numbers.
Bilstein did it when we ordered the B8 kit from Graham, swapped part numbers but it was the right kit.
Vendor
They are all correct.. ..Ford change finis codes lots so one 'part' will sometimes have about five different finis codes...... the ones you have are the latest level codes.... i use the same live system that you find in a main dealer.. .. and i worked in a main dealer for ten years in parts department
Thanks for the custom
No problem, just wanted to make sure I got it right tbh. Thank you for promptness and the free delivery, shall deff be using again! Merry Christmas
1 - 16 of 16 Posts
