1 - 20 of 20 Posts
hi all need bit of help i have like a chirping noise on start up and only on cold start . i have checked all pipes and hoses all tight . no noise when i remove dip stick belts look good any ideas please thanks 06 pre face lift st2
Mike Mk2 ST225
My girlfriend's car had this same chirp. We had all belts changed as they were about due anyway but made no difference.
I feared it was something to do with the turbo- seemed to chirp more if you got it spooling quickly enough after turning on but I think it's sorted itself out now...
Unless it has something to do with a suspected (and again temporary) misfire presumed to be a coil failing.
it sounds good no misfire runs and boost good and only does it when I live it to cool down hour or so then it does it again no faults I plugged code reader in all good
did notice my oil cap oring a bit worn going to change it to morrow . may be sucking in air when starting long shot but need to start with the simple things first . already spent a mint on running gear tracking etc lol
1 - 20 of 20 Posts
