I'm no nearer to getting to the bottom of this issue - noticeable flat spot/hesitation between 2-2.5k revs in lower gears.
I've got FORscan on my laptop, and the appropriate ELM cable, so would like to log various 'gauges' in a live environment. Can anyone recommend which sensors to log given the symptoms, as I've no experience with turbo setup. I'm making an assumption that I can run the car and then examine the historical data?? If this is not the case with this software, what should I be using?
There are no apparent DTC's , and I've cleaned the MAF and replaced the air filter (standard fitment). Car is stock.
It definitely feels like a boost issue...
TIA,
Ian
TIA,
Ian
