Hi looking for a bit of help...tried changing the outside temp to Celsius but in turn it changed the miles to kilometres!
Guy at work has miles and Celsius in his st, anyone know how I get the same?
Change it to imperial in the menu. Once you've done that. Go onto the temp display and hold the reset button.
Graham - mk2 stage 3
I thought you could swap between F and C by getting the temp display up and then pushing the select/reset button on the end of the indicator stalk.
EDIT: Not quick enough.........
