1 - 3 of 3 Posts
When fitting the facelift centre console to the pfl.
Is there any plug tapped up in the pfl loom to plug into this socket on the centre console.
If so we're would this plug be found.
Also found a plug taped to the ashtray light with 2 thin stripped wires going to it and it was a grey plug with red end.
The facelift center console has the keyless start button. This feature wasn't on the pfl so there won't be any wiring there for it. Also unless your pfl has the uncommon option of keyless start you won't be able to use the button unless you wire it up in conjunction with the ignition switch and still using the key.
Just wanted to get power to light it up.
As watched a video on YouTube of a guy who does up his pfl st.
And he owns a mk2 st1 and the plug was there on his as they used it to power up the 12v rear sockets
1 - 3 of 3 Posts
