1 - 12 of 12 Posts
Hi I was just wondering if I could have the carbon surround (the same as facelift and RS) on my pre facelift ST?
I have the older Sony headunit and DEATC climate control..
If anyone can point me in the right direction that would be great!!
Rob
Yip, it's a radio out job then unscrew and unclip the panel from the dash.
I actually got the carbon film given to me but I believe it was purchased from here, they also do real carbon fibre sheets but a bit more expensive. Heat it gently with a hairdryer and it becomes very pliable for those tight corners.
http://www.ragingspeed.com/UK/product_info...products_id=818
Dont listen to what peopple have been saying cos it is possible to do this to a pre facelift as i have done with mine, I havent got the DEATC but i have upgraded my unit and dials from green to red, its a costly way of doing it but ford dealers sll these items and trust me they are not cheap!
this is my upgraded unit http://www.focusstoc.com/forums/Unusual-Sa...unusual+sat+nav
and this my carbon fibre surround http://www.focusstoc.com/forums/There-t440...+centre+console
So good luck and if you need any more info PM me and il be happy to help!!
QUOTE(RobboST @ 5 Nov 2009, 11:02 AM) <{POST_SNAPBACK}>are there any creases in it where you had to fold it round the heater controls and around the corners of the cd player? how did you manage that, looks very neat!
Just used a hairdryer, cut the film from the outside of the hole to the centre at 1cm intervals then push the excess through, gently heating as you go and stick it to the back of the panel. Not as hard as you think really. On another note, I've since fitted an Alpine touch screen and f
g ruined all my efforts
QUOTE(stevejones4497 @ 5 Nov 2009, 01:34 PM) <{POST_SNAPBACK}>Dont listen to what peopple have been saying cos it is possible to do this to a pre facelift as i have done with mine, I havent got the DEATC but i have upgraded my unit and dials from green to red, its a costly way of doing it but ford dealers sll these items and trust me they are not cheap!
Fella, didn't you read the OP, unless you want to spend hundreds on a new stereo then you CAN'T DO IT.
QUOTEFella, didn't you read the OP, unless you want to spend hundreds on a new stereo then you CAN'T DO IT.
Well strangely enough i didnt buy a new h/u from fords good old ebay for a fraction of the cost, otherwise it would have not been feasable to do this, now as most of my parts are from ebay at v.low prices im sure this can be done for alot less! My headunit cost me £230 pounds which I think is an absolute bargain for a ford head unit with sat nav!! So as for spending hundreds of pounds its just a case of looking about!!!!!
1 - 12 of 12 Posts
