Hi
Just wondering if anyone could help me who lives near Wokingham/Bracknell if you could possibly take me out for a drive (me as passenger) in your ST, I have a Mountuned ST with other mods inc RS Clutch/Flywheel but every now and then the car feels a bit hesitant like the clutch is still slightly slipping. With the RS upgrade I very much doubt that it is and is probably a bit of turbo lag etc but would like to compare it to another ST.
For example if I am going along in say 4th gear at 40mph then put my foot down the engine note seems to pick up a bit to much before the speed increases, maybe it's just because of the Symposer pipe bringing more noise into the cabin but to me the pick up seems slightly delayed.
Does anyone else think this about the ST?
Also the clutch pedal seems to feel spongy at the top, when I went to profile Gary did mention that in other ST's the pedal springs right back up to the top whereas mine you can put your foot under the pedal and lift it up another cm or so (almost like a return spring is missing), he did say maybe could be Master cylinder is slightly fault. I understand it that the hydraulics just release the clutch and it's just mechanical pressure plate keeping it engaged so wouldn't have thought even if I had some fault it would make it slip.
Sorry to bore you but can anyone shed some light on this?
Rob
Rob
