I was with BT and had no problems connecting wireless to the hub. I am now with Sky and 4 times now i have not been able to connect to the internet. This time i cant get it to connect at all, although it is fine like now when it is conected direct with the eathanet cable.
I dont want to phone Sky technical and be on there for hours listen to them tell me what i have already tried.
First for some reason when i type in the router key number it says, not correct number although it is and have used it to connect before.
Second im not sure weather the router maybe strong enough to get a descent signal to the pc Its a Netgear with a range of 100 meter, so it should be strong enough. It is 16 feet away and through 2 plasterboard walls? Strange thing is when i do a search for wireless signals it pics up the router and can be an excellent signal strength?
Could it maybe be the network adapter? it is a Belkin 802.11g- 54mbps but this is compatible with this router.
Whats the difference between the 802.11g adapter and the 802.11b?
Also could this have anything to do with the broadband speed?
