does anyone know what size those self clamping springs are that clamp on the boost solenoid?
Then you'll have to tell ford that as they are the same ones on ford.7zap HD1they do seem a bit big for the boost solenoid!
The hose is 4mm id, od will be nearly 10mm then with hose pushed over the fittings on the solenoid will take it close to 11mm.they do seem a bit big for the boost solenoid!
