QUOTE(skay1975 @ 20 Nov 2009, 03:57 PM)
<{POST_SNAPBACK}>I have had my car checked out today and changed the spark plugs, etc.
The only problem showing up on the mechanics checks is the "boost sensor solenoid".
I went to Ford to look at getting a replacement and was told there is no such thing - they did suggest a turbo control solenoid as an alternative - are they the same thing?
And is a faulty one of these sensors likely to cause the problem I mentioned in the previous thread re. holding back the power and then it all kicking in suddenly before dropping back off again.
Stu
Mine has an occasional misfire on full boost, its been like it for about 4 months, i've had the car checked out by gary at profile, together with fitting Rs plugs and checking the car for faults, no faults were stored on the car. He did suspect the control solanoid or the map sensor were playing up? but they seemed fine?
The problem seems to be until something breaks it's very difficult to diagnose.
I find i now drive the car like a non turbo, because of this and it's a reall pain in the ****.
I'm getting the car checked out again tomorrow and will let youknow how i get on.
