1 - 11 of 11 Posts
Just checking, you are turning the key left first then right, whilst you hold it as far right as it goes and you try to lift bonnet at the same time?
Or do you mean that it's just not releasing anything at all?
it happened to me when i fitted my intercooler, my mate has a garage so i parked it over the pit took off the under trays and unbolted the actual lock and the bonnet would lift, had to order a new lock from ford thought
update...fixed! it did need the bit of plastic that the cable goes through, popping back into place, used a wire coat hanger as i didnt have long pliers to take the rubber boot off. then a screwdriver to pop the plastic bit back in! took 10 mins! thanks to all for the help! cheers
1 - 11 of 11 Posts
