hi on my st i am running the stage 2 bluefin, with a full mongoose exhaust, de cat etc,, induction,,
When you floor it mostly in the higher gears its goes for a second then you see the needle drop the revs back about 200revs then off again,,
Is this common,,,
Putting an uprated intercooler next so either go to stage 3 or bin it and get another bespoke map altogether
cheers
feels abit like a clutch slip,, sure it isn;t,,
Only noticed it when i fitted a new frt pipe and de cat
The RS Clutch is an option - but IMO 'better' and 'cheap' dont mix well when it comes to things like clutches.
What Mods you running mate?
Hi , foz i am running a mongoose turbo back with de cat, induction kit, 99 ron fuel , stage 2 bluefin,,
Its fine untill i put the de cat and frt pipe on,, must of just taken it over the limit of torque..
The rs2 clutches look the part, today it was slipping bad in 6th gear under load,,
hi chris, drove the car yesterday,, defo clutch as in higher gears the revs are just going up on there own
