Hi mateAny suggestions for block mod in South Wales area?
Whats they're work like is it top notch? As I don't like any monkey working on my carGrange service station in Cardiff
Have you got a contact number for them thxsSabre, not far over the bridge.
Their work is good we had the track Fiesta cams and timing belt done there have a look at their facebook page on 20 Aug 2020 you will see it. I know lots who have used them and not heard any bad reports. WelshFord members use them and it takes a lot to please them so must be goodWhats they're work like is it top notch? As I don't like any monkey working on my car
Think I give them a ring tomorrow.I would take a look buddy but I don't do Facebook 👍Their work is good we had the track Fiesta cams and timing belt done there have a look at their facebook page on 20 Aug 2020 you will see it. I know lots who have used them and not heard any bad reports. WelshFord members use them and it takes a lot to please them so must be goodNice guy the owner
Had mine done there too... And my previous ST was done there. James is a good guy and knows his stuff.Hi mate
I had mine done at BD Performance Aberdare
That's because nobody knows. Over the years I've seen on here bog standard engines cracking liners. Lot of people blame high temperatures but although I'n no engineer the theory that it is due to the top of the cylinders flexing a tiny amount over time starts the cracking makes the most sense to me. The block mod is to prevent this flexing where the top of the block is weak due to a groove going across between the cylinders as part of the coolant circulation.It's all confusing I've rang a few places that have been suggested and they recommended not to have it done as I'm not going for stupid bhp and another place yes?
That's interesting but that is due to low temp water hitting a hot spot, so for me it is not the high temps causing it but the cold temp of inlet water. Having said that, I doubt if water entering the engine is freezing as the circulation will keep it moving through the rad too quickly.I still think the narrow part next to the cylinder is a hot point, and mine cracked not long after upgrading radiator- freezing water coming in as the thermostat opened and cooling the narrow part rapidly killed it.
No proof just theory
In theory it's all of the above-That's interesting but that is due to low temp water hitting a hot spot, so for me it is not the high temps causing it but the cold temp of inlet water. Having said that, I doubt if water entering the engine is freezing as the circulation will keep it moving through the rad too quickly.
I don't think that the block mod in itself does any harm. Had mine dome at 79k and now on 135k miles. Running stage 3 since the block mod.It's just all seems a mine filed of what is to do for the best.Its not that I'm running the car on a shoe string as well.maintained if it needs anything it's done.always warmed up and cooled down properly and give it a booting when I can (no speed cameras lol).it's just if anything catastrophic goes wrong then it another St up for spares or repairs don't want this to happen
