1 - 2 of 2 Posts
Third attempt
you gonne need
socket 10mm ( battery )
Some flat screwdrivers different size
new airbag cover or new airbag
some lubricant
experience playing with explosives and suriving
disconnect the battery
start the car ( drain all the angry pixies )
pull out steeringwheel for more clearance
Remove plastic cover, it just pulls out on the pfl
Turn the steeringwheel to acces the spring and find the springs
There are 4 places where the spring connects to the steeringwheel
3 of them which you have to undo
when having the steeringwheel straight
there are 2 springs on the side and 1 on the bottom which you have to undo
you can undo the last spring by tilting the airbag
you should be able to tilt it slightly and have a peek inside and you will see where its connected and how to undo it
Use a flatscrewdriver outwards/upwards ( wotever way you look at it )
here you can see where the spring is attached to
the steeringwheel is upside down in the picture
below the yellow cable you see a black clip
this is the 4th place the spring is connected to
Remove the connectors
one is allready removed on the pictures ( it was lose apparantly ) the other you just squeeze and pull out
Now if your smart you just bought a complete new airbag unit instead of just the cover and you can start putting things back together
if you're like me and like a challenge its time to remove the cover
i tried removing it and keeping it intact just incase...
after completely wrecking my hands and messing with tools i decided to give up and just cut the old one
you will end up with
now install the new cover, make sure all parts of the cover are inserted into the slots before you start closing it
you defo wanna use some lubricant, else you gonne be pressing so hard you probably end up damaging it again
go back to installing
make sure the spring ( the white piece of metal is seated on the airbag properly )
make sure everything is connected
tilt the airbag so the spring goes behind the bracket on top of the airbag first
than press it in to connect the other 3 spring parts
enjoy the new look ( No clue why it decides to turn the picture, tried resaving it )
1 - 2 of 2 Posts
