QUOTE(wwfc @ 4 Nov 2009, 01:04 PM) <{POST_SNAPBACK}>My car goes in for some minor warrenty work tomorrow and its 3 month courtesy check. I will be resetting the car back to stock in case ford play around with anything, but do i need to do anything else, i.e pull the KAM fuse.
I assume my dreamscience will be undetectable by ford once removed?
many thanks.
No all you need to do is flash back to stock! Ford will not be able to tell you had the map on it as it will delete any messages when you reflash it!
many thanks.
