1 - 13 of 13 Posts
Just got in car and "acceleration reduced, engine system fault" come up on dash where the oddemeter is. No mil lights on and it's getting full boost in gear, doesn't seem anything wrong. Anyone had this problem and shed any light on it, cheers
Seen this twice before, turned out to need a new battery twice, leave the a&e running for awhile then key it off then restart it, if the message is gone I would say a battery is your best bet
Left engine run and restarted it and message gone.thanks for advice guys , better start pricing a new battery up then cos need car for work. Cold weather not good for batteries
Neil
Id get your alternator checked out that its working ok before lashing out on a new battery, just to cover all areas
Neil
Never even crossed my mind, will do firstly then go from there. £58 in Costco sounds a good deal, was thinking £100 + if it does turn out to be battery
ST225 modified
Lived with this message happening for about 18 months with my last ST - just had to recharge the battery every couple of months, esp in the Winter.
If it causes 'limp-home mode', just turn off and re-start and it will clear.
Make sure it's the right kind of battery. I think the ST has some special kind of one. At least it's not as bad as the RS battery from Ford, something in the region of £170!
1 - 13 of 13 Posts
