Is it picked up today brand new? They need a bit of time to bed in. It can also take a bit of adjustment to get used to the way the EBB feels to get the most out of it as it’s brake by wire.
EDIT
Can see it’s 2019 so unless place you bought it from just changed brakes or pads then it shouldn’t need bedding in. Perhaps just give yourself a bit of time to adjust to the EBB, but it’s probably not going to compare to big brembos. I’d think you could fit the bigger brakes from the track pack if you wanted.
EDIT 2
If you do it yourself or get a local garage to change the brakes just be aware because of the EBB the car has to be hooked up to a laptop and go through a service procedure when the fluid is changed.
EDIT
EDIT 2
