QUOTE(Thunder#59 @ 25 Nov 2009, 07:11 PM)
<{POST_SNAPBACK}>so for just the RS clutch i wont actually have to re mortgage the house for then
£160= +fitting seems ok thank god!!
Yes, that's it, unless you've already knackered your clutch completely, in which case you may need to get the flywheel skimmed or replaced. I have seen people on the forum talking about having to replace the flywheel, provided the car has not been abused by launching off the lights at every occasion, I see no reason why this would be necessary.
If you want someone to do a good job for you, speak to Mark Shead at MA Developments, near Maidenhead. He is reliable and trustworthy and has also done this job on the ST. Check out his website
http://www.madevelopments.com if you need any further info.
